FSI electronic ign on model a What degrees do you see the timing on an FSI electronic ignition?
Re: FSI electronic ign on model a The electronic does not change the way it is timed.
So, it gets timed the same way with the pin, or light or nurex wrench for TDC |
Re: FSI electronic ign on model a I time my truck with a timing light at 2 1/2 degrees BTC. The distributor is limited to 20 degrees of total advance because of my Brumfield 5.9 head.
Re: FSI electronic ign on model a My rebuilder did work to my FS, he said not to exceed 26 degrees of total advance.
Re: FSI electronic ign on model a 1 Attachment(s)
Bc, do you have a standard 4.2 head or a HC head?
What AL and 1929 are saying is correct for a HC head. If you have a standard head as the pin goes in you want TDC and the rotor pointing to #1. As in the photo. |
