Rear End Gear Ratio How can I tell what ratio I have in my '31 Pickup? Is there a tag anywhere?
Re: Rear End Gear Ratio Quote:
If you have it apart you might consider replacing the rear spring with one from a roadster (unless you plan to use it as a truck). Charlie Stephens |
Re: Rear End Gear Ratio Charlie
Thank you for the rear springs (roadster) change out. I don't use it as a Pickup. It's one rough ride for sure. Thanks for information never expected. |
Mark the tyre at 12 O'Clock. Set hand brake to just drag a little. Select 3rd gear. Turn engine exactly 2 turns with the crank handle(easier if the plugs are out). If the mark stops at 11-12 O'Clock, you have 4.11 If the mark stops at 12-1 O'Clock, you have 3.78 If the mark stops at 1-2 O'Clock, you have 3.54 |
Re: Rear End Gear Ratio 1 Attachment(s)
See attached.
Tom Endy |
What is the most desirable ratio. I drive for pleasure. It's neat when I get information - even when it's about other than asked (roadster springs) Thanks |
Re: Rear End Gear Ratio Don't mean to high jack this tread but speaking of springs has anyone had experience with an 8 leaf spring in a Tudor that should have a 10 leaf pack. Will it ride better but still sit right when not loaded.
The quick answer to your questions is No, ...and No. Start a new thread and we will get into why this is. |
Re: Rear End Gear Ratio Fitz, the best ratio for you depends on the type of driving you do. I like 4.11's and an overdrive, gives good performance around town and is great on the highway.
Jim No overdrive. I drive just around the city, no expressways at all. For my Pickup, only will drive secondary roadways. I've no modifications, except for a Randy Gross steering box. Am very interested in the opnions of others whom are stock. Thanks |
Re: Rear End Gear Ratio Who cares what the rear end ratio is??? As long as you're HAPPY, drivin' it.
Bill Nottoworry |
