The Ford Barn
-   -   Speedometer gear question (https://www.fordbarn.com/forum/showthread.php?t=250637)
cowtown 09-01-2018 06:01 PM
I have a 49 tudor that the speedometer reads faster than I am really driving. When the speedo reads 60 mph I am really going about 52-53 mph. I am running a 21 tooth gear which I thought was original to the car. (16,000 mile original car) Should I be running a 19 tooth gear???
JSeery 09-01-2018 10:26 PM
Re: Speedometer gear question
There are usually charts that specify rear axal gear ratios and tire size to a recommended speedometer gear (tooth count). The green book has such a list for pre-49 car/trucks. Should be a similar table for post-49.
Phil Gillespie 09-01-2018 10:50 PM
As mentioned the correct tyre size and rear end ratio aas per chart and if this is correct then go with the recommended tooth count as per chart.
Dropping down to a 20 tooth could assist. A 19 tooth could be too much.
Had similar problem and ended up removing speedo for calibration check.
Phil NZ
Charlie Stephens 09-01-2018 11:05 PM
How does the odometer read? If it is correct then it is time to fix the speedometer.
Charlie Stephens
rotorwrench 09-02-2018 08:14 AM
There used to be a lot more speedometer shops that had equipment to check accuracy back in the day. Now, not so much. The chassis parts book for the shoe box Fords will list the gears. I just hope you can find the one that matches your axle ratio and tire size. If you find that you already have the correct gear for your combo, your only recourse would be to get the speedometer serviced and calibrated.
38bill 09-02-2018 11:24 AM
If the speedometer is reading fast then you need a larger driven gear to slow the cable down. When I was running a std driveline with a 3:54 rear end I moved from a 19 tooth gear up to a 21 tooth. The 19 read way too fast and the 21 got me about as close as you are. There are also some adjustments that can be made to the speedometer itself. I'm just crazy enough to try to fix almost anything and I was able to get mine within a couple of mph's by messing with the speedo adjustments. You may want to send yours in to an expert.
rotorwrench 09-02-2018 05:50 PM
Stewart Warner made ratio adapters that can be installed in line with the cable but I don't know if they fit the old drives. It would take some research to find out.
papanick 09-03-2018 10:39 AM
Hay I can service your speedometer and set the speed.Email me at [email protected]
I do have the equipment to calibrated the speed.
