The Ford Barn
-   -   Oiling springs (https://www.fordbarn.com/forum/showthread.php?t=249139)
Ian in Mississauga 08-06-2018 06:18 PM
Oiling springs
I just put good rebuilt shocks on the front of my car and then oiled the spring with oil from the crankcase. A friend questioned my choice of oil. I thought I read that here on fordbarn but now I can't find it. Did I just screw up?
Synchro909 08-06-2018 06:22 PM
Re: Oiling springs
No, any old oil lubricates better than rust. Some people, myself included have used all sorts of fancy stuff but they all do the same thing.
Drive on and enjoy your car, I say.
The only downside to using a wet lubricant is that dirt will stick to it. I have fitted covers to the springs on my ost used cars.
Hoogah 08-06-2018 08:42 PM
Re: Oiling springs
Synchro & Ian, how did you apply the oil to springs in situ? Does it draw itself into the gaps by capillary action?
Synchro909 08-06-2018 08:48 PM
Re: Oiling springs
I made myself a hardened "spike" like a hollow screw driver and a grease nipple on the side. The spike ius driven in between the leaves and oil or grease pumped in. Even an ordinary screw driver would open the leaves enough to squirt in some oil, I think. It will work its way along the leaves as you go.
Tacoma Bob 08-06-2018 10:43 PM
Re: Oiling springs
Kroil has a product that is designed to travel horizontally between the leaves.
Hoogah 08-07-2018 01:54 AM
Re: Oiling springs
Is this it? https://www.ebay.com/itm/Kano-Kroil-...0AAOSwOBBbT34h
brokenspoke 08-07-2018 08:00 AM
Re: Oiling springs
Slip plate paint is what I use
katy 08-07-2018 08:14 AM
Re: Oiling springs
1 Attachment(s)
They used to make a tool for spreading the leaves:
Tacoma Bob 08-07-2018 09:34 AM
Re: Oiling springs
Originally Posted by Hoogah (Post 1660105)
No...That appears to be their"flagship" product. Penophyte is their product for applying to assembled spring packs. Hope this helps.
Purdy Swoft 08-07-2018 11:29 AM
Re: Oiling springs
If a person is running without shocks , it is probably best not to oil the springs or it will bounce real bad .
jb-ob 08-07-2018 11:57 AM
Re: Oiling springs
Hoogha,
With the car supported with jack stands under the frame, wheels off, and a floor jack under the front end, lower the front end as far as the shocks will allow. With the weight off the front end, the spring will relax and easy to squirt your favorite lube between the leaves. This is also the best time to grease king pins and shackles.
Same technique works for the rear.
JB
