The Ford Barn
-   Questions & Suggestions (https://www.fordbarn.com/forum/forumdisplay.php?f=12)
-   -   1931 Model a victoria (https://www.fordbarn.com/forum/showthread.php?t=245411)
djuby1 06-02-2018 04:57 PM
How do you install the double arm regulator in the door. I needed to shem the glass channel so the window did not jam. was able to get everything out and cleaned up but I am having problems getting the regulator back in with the arms in the slide mechanism. Any advice would be hepful.
Charlie Stephens 06-02-2018 09:17 PM
Re: 1931 Model a victoria
I am sorry I can't help with your question but would like to suggest you repost it in the main Model A forum, https://www.fordbarn.com/forum/forumdisplay.php?f=3 You have posted in a forum intended for questions to the editors. Good luck.
Charlie Stephens
