The Ford Barn
-   -   Autolite 216 gap? (https://www.fordbarn.com/forum/showthread.php?t=244504)
46woodie 05-17-2018 01:45 PM
Autolite 216 gap?
My flathead for my 46 V8 is using the 216 Autolite plugs. What is a good gap for these? Are the Champion H10's a better choice,same gap as autolites? Thanks
DD931 05-17-2018 01:56 PM
Re: Autolite 216 gap?
I'm old-fashioned. To me, Champions belong in Fords, Autolites in Plymouths and ACs in Chevys. Nowadays, of course, we are much more ecumenical!! I don't know any reason why the plug gap should be different among brands. If you like Autolites, go for it!!!
Mart 05-17-2018 02:06 PM
I Use the Autolites, with no more than .027" for the gap. I had a round of problems with the HT side of the ignition and always like to limit the HT load by not going mad on the plug gap.
Mart.
BUBBAS IGNITION 05-17-2018 02:25 PM
Plug gap goes with engine not the ignition.........flatheads run .025
Ggmac 05-17-2018 02:46 PM
.025"
4dFord/SC 05-17-2018 03:34 PM
The Autolite 437's I recently installed in my Offenhauser heads were .025 right out of the box.
revkev6 05-17-2018 04:39 PM
Huh.. that contradicts what msd's I instructions say... higher compression the tighter the gap... started at .050 and dropped to .045 when I bumped compression
46woodie 05-17-2018 05:35 PM
This engine is bone stock,going with .025. Thanks everyone!
