'41 Brake Pedal Bushing The brake pedal is a little loose on its pivot and I have the replacement bushing. Pulled the floorboard last night and am wondering if I can even get the pedal off of the pivot, due to little clearance between the brake pedal pivot and the side of the transmission.
I guess I could remove the side plate from the transmission, but would rather avoid, if possible. So, will the pedal come off without taking other stuff apart, or not? Are there any tricks in removing and replacing the copper (bronze?) bushing? Thanks, |
Re: '41 Brake Pedal Bushing I would put the floor back in and think about it for a while. I do not believe you should remove the side plate. Difficult to remove and much harder to replace.
JMHO Bruce |
Re: '41 Brake Pedal Bushing Quote:
Re: '41 Brake Pedal Bushing I will dismount the pedal assembly far enough to get the brake pedal off. The bushing on the clutch side is fine.
Are there any tricks to get the new bushing in? Do I need a press, or can I do it with a mallet and some finesse? |
Re: '41 Brake Pedal Bushing Would be nice if you have a pilot shaft with correct ID and OD of bushing so bushing goes in squarely without collapsing. Kind of like a cam bearing install tool, only much smaller. If you have a lathe you can make one.
Re: '41 Brake Pedal Bushing You may be able to remove it by using something like a small screw driver in the edge and collapse the bush .If the bush is a .3 Thou interference fit it should tap in with a small steel hammer tapping evenly around the edge ,if its larger it might collapse ,it may need reaming to fit the shaft .
Re: '41 Brake Pedal Bushing For items like this I usually use a bench vise and press them in. Sometimes you would like to be blessed with three hands !
