Gano filter picture Does anybody have a picture of it installed in there car ?? Picture please. Thank you
Re: Gano filter picture 1 Attachment(s)
Here's a shot of it in the coupe I just purchased. I can get you a close up tomorrow.
Re: Gano filter picture What is a Gano filter ???
Re: Gano filter picture Quote:
The Gano Auto Coolant Filter is a patented device that prevents radiator and coolant system damage. It removes rust scale, gasket material and other foreign particles from the cooling system before they can build-up and clog or block radiator cooling tubes. It is also used as a diagnostic tool for analyzing overall coolant system operation by providing a “window” into the over-all flow of coolant. The Gano Filter is an accessory to the cooling system, designed to be installed in the upper radiator hose of your automobile. It is a full flow device, which traps foreign particles thus avoiding radiator repair or replacement due to clogging. http://ganofilters.com/ |
