The Ford Barn
-   -   5 speed trans on a flethead (https://www.fordbarn.com/forum/showthread.php?t=243233)
bobgc 04-24-2018 06:49 PM
some time ago I saw a 36 panel truck which had a five speed od trans in it and still had the closed drive shaft, anyone know how you do that? I am considering doing the same. I know you can do that with a s-10 trans but you have convert to open drive and I would rather not do that if I don't have to.
JSeery 04-24-2018 07:10 PM
Re: 5 speed trans on a flethead
You can do it with a T5. There was a detailed thread on the setup, an adapter to the closed driveshaft is used in place of the normal tail cone piece.
bobgc 04-24-2018 07:21 PM
I am not sure I know what a T5 is I have a 5 spd. from a 94 F350 will that work ?
cas3 04-24-2018 07:25 PM
thats an awful big transmission. try this...google- t5 fordbarn you will be reading into next week
JSeery 04-24-2018 07:27 PM
T5s were used in S10 pickups, Camaros, Mustangs, and other cars/trucks. Anything can be made to work with anything if you spend enough time and money! :) The T5 is a proven approach with lots of supporting data.
https://www.fordbarn.com/forum/showt...t=transmission
cas3 04-24-2018 07:31 PM
and, as a bonus that f350 trans is worth a lot if its known to be good. that would finance a big chunk of a t5 project
bobgc 04-24-2018 08:01 PM
Ok thanks for your help i'll go on the site and read all about it thanks again
