What is safest way to remove a rear end that has a broken rear spring center bolt? I have a rebuilt Tom Endy transmission that I will be putting in my 29 pickup, sometime in the future. Normally, i would leave the rear spring in the car and just drop the rear end, but I noticed that the rear spring has a broken center bolt, which I would like to replace.
I am thinking of putting some C clamps on the springs, clamping as many leaves as possible, then removing the 4 nuts that hold the spring assembly to the cross member. The upper leaves are flatter and should not have much pressure. I would appreciate your thoughts. I know I could just leave the spring alone and leave it for the next guy to contend with, but I'd rather fix it now. |
Re: What is safest way to remove a rear end that has a broken rear spring center bolt Neil, remove the rear end from the spring while the spring is still captured in the frame with the 'U" bolts in the normal manner with a spring spreader. Relax the spring on the spreader and then carefully remove the spring from the car using good strong "c" clamps, 2 on each end facing opposite directions on the leaf ends as close to the center as possible. Slack the 'U' bolt nuts and remove the spring with the "c" clamps on it. If the center bolt hole in the spring is open, add a piece of allthread rod with nuts on each side of the spring as added insurance and begin to carefully slack off the allthread nuts and the "c" clamps until the spring tension is relieved.
Be careful as the spring has stored energy and is also heavy. John |
Re: What is safest way to remove a rear end that has a broken rear spring center bolt Neal:
Go to the post below "removing the spring...." The answer I provided is the way you should handle the broken center bolt. As long as the spring is attached to the frame with the two U-bolts it is safe. Use a spring spreader to be able to remove the shackle bolts and drop the rear axle assembly. Then collapse the spring spreader and remove it. The spring is safe then, unbolt the U-bolts and take the spring out. Removing a rear axle assembly with the spring attached is a dangerous practice, but people do it all the time. About the time you are wrapping chains around it may be the time it decides to explode on you. Tom Endy |
Re: What is safest way to remove a rear end that has a broken rear spring center bolt It should be possible to access the top of the rear cross member within the car? if so, one could drive out the broken bolt and replace it in-situ?
Re: What is safest way to remove a rear end that has a broken rear spring center bolt I would just use the weight of the car to do the job.
Undo the 2 U bolts and simply jack the chassis up. All the upper leaves will loosen off, just leaving the main springleaf across the shackles. |
Re: What is safest way to remove a rear end that has a broken rear spring center bolt Quote:
Also, this would be a good time to clean up the spring and paint it w/slip-plate or your choice of poison before re-assembling it. |
Re: What is safest way to remove a rear end that has a broken rear spring center bolt I did that on a sedan once, and it was very dicey. Since you have a pickup, you don't have much weight in the rear end, so some of the suggestions above do not apply (or will kill you).
Doing as Tom suggests in the post he forgot to link is to remove the spring from the perches using a spring spreader, then after the spring is off, removing the 4 bolts from the center and it all falls out. When I tried that, as the nuts in the center were being balanced out, suddenly one of them stripped off the threads and all hell broke loose. The fury released immedately in less than the blink of an eye. I suggest a slight modification of Tom's approach- Remove the cotter pins from the four center castle nuts and back them off to release some of the tension first. Just back them off until the valleys of the castlated parts of the nuts are even with the ends of the bolts. Then, proceed using Tom's method. Using C-clamps seems to help, but that is pretty dangerous because the spring will bend them! |
Re: What is safest way to remove a rear end that has a broken rear spring center bolt Take it to a spring shop. No need to be a hero--especially a dead one.
(They even found the 3 missing fingers, to bury with him & his WATCH, so he wouldn't be "LATE"!) Bill Chicken |
This is a far safer method if you are just replacing the bolt. If you are not going to do anything else to the spring then just leave the U-Bolts alone. |
Bill Simpleton |
Re: What is safest way to remove a rear end that has a broken rear spring center bolt If you can replace the center bolt with it all installed, go for that. If you can't get a new bolt to drop in, then use the wieght of the vehicle to keep the spring together, even if you have to add some wieght. You can then be well out of harm's way while lifting the vehicle, and in no danger if it suddenly goes kablewy. This is by far the safest way.
Jmho |
Re: What is safest way to remove a rear end that has a broken rear spring center bolt Get your next door neighbor to help...Then disappear.
Re: What is safest way to remove a rear end that has a broken rear spring center bolt I wonder why it is that just because these cars are older than us, there's something shameful about seeking professional help for fixing them. I include myself in this vanity or foolishness or stubbornness or whatever it is: until very recently, I even had the same hangup about rolling around under my Ford to grease it.
Most of us have for years been taking our modern cars to shops for all manner of servicing, without any qualms of conscience--even BEFORE computerization rendered them virtually inscrutable! In most fundamental respects, the Model A Ford is still a modern car. I say, it's great to work on and fix our cars ourselves if it's fun and you reasonably and safely can, but there's no shame in showing deserved respect both to those who have chosen to make a profession of being a mechanic and to the wonderful pieces of machinery that merit their services. There, I've gotten that off my mind! Now, if I only could believe it. |
Re: What is safest way to remove a rear end that has a broken rear spring center bolt Almost every time that I've taken a car for repair, it has not been fixed, but screwed up by an incompetent "mechanic". Mind you, I've only rarely taken one in, I'd much rather do a bit of research and fix it myself. Modern cars are actually pretty easy to work on once you understand how to make use of the diagnostic tools. Very rarely is there a problem it doesn't diagnose for you. The worst part is how tightly things are packed in.
Re: What is safest way to remove a rear end that has a broken rear spring center bolt Thank you everyone.
I am definitely using a professional spring spreader to remove the rear end. If i can just replace the broken bolt, I will not remove the spring, at all. I'll let you know what happens. |
