What is the dimention of the rear body block on a 29 tudor? Does anyone have the dimension of the rear body blocks on a 29 tudor.
I need to know the height (from frame to under side of body). I'm thinking it is around 1 and 1/2 inches high. LWH would be nice too? Thanks, Neil |
Re: What is the dimention of the rear body block on a 29 tudor? 4 Attachment(s)
Neil, here's some dimension labelled pictures of the blocks I took a few years ago when somewhat else needed the info:
Re: What is the dimention of the rear body block on a 29 tudor? Those are good dimensions for the original 1929 blocks.
According to the service bulletins, July-August page 577 the length was increased to 6 inches, from 3 inches, with the angled cut portion increased to 4 1/8 from 1 1/4. |
Re: What is the dimention of the rear body block on a 29 tudor? Thank you gentlemen!
