The Ford Barn
-   -   Shift tower fork rivet tool (https://www.fordbarn.com/forum/showthread.php?t=241006)
wrndln 03-17-2018 11:15 PM
Does anyone have a picture (or information) for a shift tower fork rivet tool than "sets" the semi-tubular rivets that hold the shift forks on the shafts? It seems like a small C clamp with the adjustable screw end removed and the end ground into a point would hold the rivet as the pointed end would "set" (spread) the rivet end. I haven't seen a tool like this on Fordbarn that I can remember. Maybe there is a better way, but I can't see how to get access to holding the rivet head while trying to spread the other end other than a C clamp type of tool.
Rusty Nelson
Tom Endy 03-17-2018 11:32 PM
Re: Shift tower fork rivet tool
I use a short pointed drift. I insert it into the hole in the fork and the shaft. When the tubular rivet is inserted in the hole on the opposite side the drift guides the rivet into place. All I do then is wallow the tubular rivet around with the drift enough to make sure it won't come back out.
Tom Endy
RandyinUtah 03-18-2018 12:38 AM
I agree with Tom. No need for a great amount of force on the original type tube rivet
Mike V. Florida 03-18-2018 09:20 AM
Use a small modified c-clamp.
Tom Wesenberg 03-18-2018 01:07 PM
Tom Endy
I do it exactly the same way.
