The Ford Barn
-   -   1930 Cabriolet windshield hinge bolts (https://www.fordbarn.com/forum/showthread.php?t=240636)
kimeccles 03-11-2018 11:56 AM
On a 1930 Cabriolet does the windshield hinge get screwed in from the bottom of the hinge into the weatherstrip into the top frame and if so do the round head bolts 1/4 diameter by 3/4 long have any special lockwashers?
thanks
jw hash 03-11-2018 03:36 PM
Re: 1930 Cabriolet windshield hinge bolts
they are 1/4-20 X 5/8 slotted round head screws with a lock washer. and you are correct the screw goes through the hinge - rubber - and into the fixed nuts in the header.
kimeccles 03-11-2018 03:43 PM
Thanks! Mine were rusty at the top because they were too long and real hard to get out. I will get new ones 5/8 and they should fit correctly.
Thanks again!
