The Ford Barn
-   -   Late 31 Carb-rebuild (https://www.fordbarn.com/forum/showthread.php?t=240579)
sphooch 03-10-2018 04:10 PM
HI guys, I need a couple answers here; 1st some one drilled out the carb mounting flanges to 5/8 in. can I use a heli -coil to bring them back for the correct bolt? OR can I fill the holes with weld and redrill and tap?? 2nd- I'm gonna try my hand at welding a broken carb. flange , its my understanding that I need to get the cast beyond cherry red, in doing so will I melt the brass plugs ?? if so how do I remove the plugs? what size drill bit is the small one? and is it a big deal to remove and replace the plugs.I never did this work before and I don't want to destroy the carbs. thanks a lot THE HOOCH
Brentwood Bob 03-10-2018 08:22 PM
Re: Late 31 Carb-rebuild
I would use a good core. The problems you have tell me the junk carb is a door stop.
DJ S 03-10-2018 08:30 PM
I agree...
Chuck Sea/Tac 03-11-2018 01:17 AM
A helicoiled carb works fine. I would find a n experienced welder to do the flange. If it’s broken near the idle jet, then that’s a problem. The late 31 has a thinner flange, and breaks easier. I’ve had a welded B carb( which also has the thin flange) and it rebroke later.
Synchro909 03-11-2018 03:28 AM
I have late zenith carburettor on which one of the mounting tabs was broken. Out of 6 mm (1/4") steel, I made a spacer the same shape and size as the gasket that goes between the carb and manifold, then brazed that to the top. No problems.;)
sphooch 03-11-2018 08:55 AM
Thank you for the info ,I'll give thehelicoil a shot. the hooch
sphooch 03-11-2018 08:57 AM
This sounds like a workable solution which I can try .thank you. THE HOOCH
