Gas line How far should the gas line from the gas tank go into the tank? On my 37 sdn the line goes in about 2.5”. Should it go in to the bottom of the tank just off the bottom? Thanks,Don
Re: Gas line About 1/2" past the ferrule is more than enough.
Re: Gas line Quote:
Re: Gas line Quote:
Re: Gas line Well, that would make a difference! For some reason I was thinking of a later tank!
Re: Gas line Yes Kube is right. Is there a pickup pipe that extends to the bottom of the tank?
Re: Gas line Quote:
Re: Gas line Most internal tank pick up tubes in the more modern Fords have this feature. They do act as a stand pipe but only about the diameter of the tube off the bottom. It's important to leave a space for water and other heavier than fuel debris to settle.
Aircraft tanks have a sump on the bottom with a water drain valve but automobiles seldom have a feature like this, if ever. |
Re: Gas line I think the aftermarket tanks the tube has to go near bottom of tank.
There has been problem with 1/2 tank of gas and no gas to start. |
