The Ford Barn
-   -   Isky cam, (https://www.fordbarn.com/forum/showthread.php?t=240157)
jimTN 03-02-2018 05:12 PM
Isky cam,
How radical is a Isky 1007-R cam?
Flathead 03-02-2018 07:59 PM
Re: Isky cam,
I've heard of 1007LD or LDB but not an R. Maybe someone will know.
jimTN 03-02-2018 10:59 PM
Re: Isky cam,
It gets stranger, I put the magnifiers on and it is a 1007B. Hoping its mild cause I was looking for a decent 5T and ever block I have has the cam and valves pulled and the cams I found were rusty. The 1007B is in good shape.
JWL 03-03-2018 12:00 AM
Re: Isky cam,
That is a great performance cam. Will run circles around many other cams. You need good compression and larger bore and stroke to really see the benefits. Also helps to have a light car and/or big rear gear.
jimTN 03-03-2018 09:20 AM
Re: Isky cam,
Thanks JWL.
