The Ford Barn
-   -   Oil again (https://www.fordbarn.com/forum/showthread.php?t=239947)
Ford coupe 02-26-2018 09:31 PM
Oil again
Since Rotella has taken the zinc out of its oil what can I do with my 36 and 55 in which I used the Rotella..Cant come up with oil containing zink here in Canada so maybe I will have to add ZDDP but if so how much? Looking for abetter way forward and hope you guys can help..Also do I really need it???
Talkwrench 02-26-2018 09:55 PM
Re: Oil again
Should be plenty of other brands around surely, what's Canada doing? I wouldn't obsess about zinc but you will need some, more so for your 55, just going to have to add the zinc...
40 Deluxe 02-26-2018 10:00 PM
Re: Oil again
If zinc is really all that necessary, how does anybody get by using non-detergent oil?? (especially for break-in, when zinc is needed the most?)
50fordcoupeman 02-26-2018 10:16 PM
Re: Oil again
Valvoline VR1 racing oil has zinc. Most auto stores here in the US has it but don't know in Canada. Has Canada done away with all zinc containing oils?
Drbrown 02-26-2018 10:29 PM
Re: Oil again
I use Rislone zinc and phos additive in both my '47 and '84 in differing quantities as recommended by them.
deuce_roadster 02-26-2018 10:39 PM
Re: Oil again
I like 50fordcoupeman use Valvolene VR1 racing oil which does have enough zddp for flat tappet engines. I would just as soon not have to add something else to the oil.
Kahuna 02-26-2018 10:40 PM
Re: Oil again
See if you can find Chevron Custom Supreme oil in your area.
It's great oil, has a good amount of Zinc & here I can buy it
at Costco.
Just a suggestion
outlaw 02-26-2018 11:45 PM
Re: Oil again
What weight VH1 are you using? What weight do you recommend for break-in oil in VH1?
flatheadmurre 02-27-2018 01:29 AM
Re: Oil again
For break-in you want an oil without friction modifiers added to let your rings seat.
Buy an oil design for the job...lots of brands have them.
flatjack9 02-27-2018 10:02 AM
Re: Oil again
Remember, there was no such thing as a zinc additive in 1935.
flathead48 02-27-2018 10:09 AM
Re: Oil again
Penngrade has zine as well as VR 1, both very good oils.
fiveof10 02-27-2018 01:50 PM
Re: Oil again
Haggerty has a nice article on oil compatibility for classic autos. You may also want to check locally about the availability of Classic Car Motor Oil or Schaeffer Oil which both have zinc incorporated in their formulation. The link to Haggerty article:
https://www.hagerty.com/articles-videos/Articles/2013/08/07/Classic-Oil
37fatfender 02-27-2018 07:23 PM
Re: Oil again
STP in the blue bottle, says it right on the front label.
40 Deluxe 02-28-2018 01:36 AM
Re: Oil again
You just hush, flatjack! You'll spoil their fun. Don't confuse them with the facts!
flatheadmurre 02-28-2018 02:17 AM
Re: Oil again
A fact is that Phosphor and ZDDP is the best oil additives invented and only taken away because of catalytic converters.
You donīt need a crazy amount of it in a flathead but why not use an additive that works like a wearshield on your lifters.
Please tell me what is bad for the engine with using an oil with phosphor and ZDDP compared to an oil without them.
Merc Cruzer 02-28-2018 09:02 AM
Re: Oil again
1 Attachment(s)
Each oil change I just add a bottle. I get it at the local NAPA store. A bit pricey.
Ron Pilger 02-28-2018 09:12 AM
Re: Oil again
the never-to-end-soon lubricants discussion (zinc/600w/corn head/WD-40/non-detergent/break-in and so on) always reminds me of weight loss supplements, health food products and armchair quarter-backing. Interesting perspectives, no end to solid advice and the occasional facts. And, ultimately no one is ever wrong.
outlaw 02-28-2018 10:17 AM
Re: Oil again
So what weight VH1 is everyone using for normal running? I have not bought any and am curious.
JSeery 02-28-2018 11:17 AM
Re: Oil again
Yes, to much ZDDP is damaging, but I'm starting to agree more and more with Ron Pilger!
50fordcoupeman 02-28-2018 11:22 AM
Re: Oil again
I am using VR1 20/50.
