The Ford Barn
-   -   What are these? (https://www.fordbarn.com/forum/showthread.php?t=239626)
37Flat 02-21-2018 04:16 PM
What are these?
1 Attachment(s)
After two moves and a few years off of working on my truck, I've forgotten things. Any idea what these are? Probably should know, but I don't.
Chris
TJ 02-21-2018 04:24 PM
Re: What are these?
Looks like lock pins for the steering column ignition lock.
RalphM 02-21-2018 04:37 PM
Re: What are these?
1 Attachment(s)
Transmission shift tower screws.
# 7238
51 MERC-CT 02-21-2018 04:46 PM
Re: What are these?
Oil gallery plugs ?
alanwoodieman 02-21-2018 04:46 PM
Re: What are these?
go in the engine behind the cam gear in front and rear in some motors above the oil pump/cam drive gears housing. plugs for the tube at either end of it. if you leave them out--NO oil pressure
RalphM 02-21-2018 04:48 PM
Re: What are these?
Your correct, I was thinking tranny.
JM 35 Sedan 02-21-2018 08:28 PM
Re: What are these?
I've only seen those special threaded plugs used as the front galley plugs. I've heard that unthreaded projection has something to do with regulating/restricting oil flow. I've never seen that type of plug used in the back of the block as a galley plug. I had made a similar post here years ago, and the engine guru's posting at that time had no idea why that front plug had that untreaded projection. Some said they just used a standard commercially available threaded plug w/o that projection on their rebuilds.
Ronnieroadster 02-21-2018 08:35 PM
Re: What are these?
Originally Posted by 51 MERC-CT (Post 1596169)
Oil gallery plugs ?
And the winner is Yes oil gallery plugs
Talkwrench 02-21-2018 08:45 PM
Re: What are these?
Im sayin' galley plugs... Christ don't leave them out !
pooch 02-21-2018 09:41 PM
Re: What are these?
My C69A block had the tapered plugs but no projections like that.
37Flat 02-22-2018 10:43 AM
Re: What are these?
1 Attachment(s)
If I'm looking right, this is what is there. The silver plug was put in by the machinist that installed the full flow system (Red's). Not finding anything on the other end. Am I understanding what you're describing?
JM 35 Sedan 02-22-2018 01:27 PM
Re: What are these?
The galley plug you have pictured in your first post goes in the front of the block, behind the timing gear. It does not go in the back of block as shown in the picture you just posted. That's a larger diameter threaded plug in back. You can use a standard commercially available plug back there as long as it allows the gear cover plate to rest flat on the gasket surface, and it appears your machinist did use a stand plug back there. You should have one of the special plugs, with an extended projection, in the front threaded hole in the block, even though many here will tell you otherwise.
37Flat 02-22-2018 03:12 PM
Re: What are these?
Thanks for the clarification, John and to everyone else for the help. It's going to run someday!
Ronnieroadster 02-22-2018 03:42 PM
Re: What are these?
Theres a lot of restriction in those fittings to the flow of oil needed at the rear main bearing lots of effort to not solve a problem the way I see it. Be careful with how thats designed and what its expected to do one leak and you will have oil going where you dont want it. Plus it will drop the flow to the rest of the engine since its taped off the main oil feed passage.
Good Luck
JM 35 Sedan 02-23-2018 12:09 AM
Re: What are these?
1 Attachment(s)
37Flat, I looked at an enlarged view of the picture you posted of the back of your engine, and the rear oil galley plug installed by your machinist does not appear to be below the gasket surface for the gear cover plate. In other words, if that plug is not sub flush, the cover plate will not seal properly, and you will have an oil leak in that area. Just saying, check it out to make sure.
51 MERC-CT 02-23-2018 08:54 AM
Re: What are these?
GOOD CATCH! Also check the front plug for interference with the cam/cam gear or bolts that may be too long.
russcc 02-23-2018 11:19 AM
Re: What are these?
Curious as to what the purpose and theory is behind the two elbow fitting and oil line in the rear of the block. Are there any advantages to this plumbing arrangement over the others for additional oil filtration ?
JM 35 Sedan 02-23-2018 12:25 PM
Re: What are these?
That was part of Reds, of Reds Headers, Full Flow Oil Filtering Kit. That plumbing in the rear of the block provided filtered oil to the rear main. At least that's what I recall reading here on this forum and also on the info provided with the FF kit that I purchased from Reds.
When I installed his kit on my last 59a build, I eliminated that rear plumbing because of concerns of damaging that tubing and having oil leaks in an area that's difficult to access behind the flywheel.
russcc 02-24-2018 12:27 PM
Re: What are these?
Thank you for the heads up on the oil line & fittings at the rear of the block. Does Red's header still sell the oil filtration system ?
37Flat 02-24-2018 05:54 PM
Re: What are these?
Thanks for the heads up. That plug is too long for the hole. Have to get another one. Haven't checked the front one yet, but at least I know what to look for now.
Thanks again.
