OEM grease zerks on 31 Slant Trying to grease a 31 SW with org. grease zerks. Been unable to get grease in through them. Is there a trick or special tool?
My truck has modern fitting and no problem greasing with hand grease gun. Thanks |
Re: OEM grease zerks on 31 Slant Most of the suppliers sell an adapter that screws on to your grease gun to replace the tip that is there. Snyders part number is 335032. Alternately you could use the original gun supplied with the car.
Re: OEM grease zerks on 31 Slant I use the adapter and a pneumatic grease gun, works great!!!
Re: OEM grease zerks on 31 Slant Heat the fitting and part to be greased so the old rock hard grease softens.
Re: OEM grease zerks on 31 Slant I use my original grease gun, that I rebuilt!
