The Ford Barn
-   -   Brake Switch to Brake Pedal connection (https://www.fordbarn.com/forum/showthread.php?t=238766)
Ford1930 02-07-2018 05:11 AM
1 Attachment(s)
My 1929 Phaeton is missing the link between the Brake Switch and the Brake Pedal. What do I need to buy to connect? Please send a picture of the connection between the Pedal and the Switch.
3.6rs 02-07-2018 05:43 AM
Re: Brake Switch to Brake Pedal connection
I made a simple solution with a motorcycle (rear)brake switch. Not original but works perfect.
3.6rs 02-07-2018 06:05 AM
1 Attachment(s)
Something like this
Sparky 02-07-2018 07:42 AM
1 Attachment(s)
Do you mean this? It's a stop light switch link.
29closedcabguy 02-07-2018 08:22 AM
Snydersantiqueauto.com part #A-13507 $1.50 stop light link for 28-29.
Will N 02-07-2018 09:29 AM
1 Attachment(s)
If I remember correctly, the clevis pin that attaches the brake pedal lever to the short brake rod that operates the cross shaft is special. There is an extension post or head on the pin that has a notch in it, rather than the pan head of a normal clevis pin. The link shown in post #4 connects this post to the switch.
Yup- found it at brattons: https://www.brattons.com/28-july-29-...levis-pin.html
katy 02-07-2018 09:42 AM
Looking at Sparly's picture, it should be easy enough to fabricate one out of an old wire coat hanger.
