The Ford Barn
-   -   Steering box Id. (https://www.fordbarn.com/forum/showthread.php?t=237433)
Chalkie 01-18-2018 12:43 PM
Steering box Id.
3 Attachment(s)
Good evening. My names Stephen I'm from the UK.
I'm currently building up a Model a chassis and i brought a steering box and told it was off a model A. I've stripped as it doesn't hold its oil and I hated the color it was painted I require a gasket kit as previous it was shimmed with gaskets on the bottom for the input shaft. unfortunately I'm not 100% sure that it is a model a steering box thanks to google. issue is I can't find it if I google the part Numbers off it.
on the steering box stamped on the main body is
CRTAAF
3550-A
Ingersoll
Machine
on the side of the steering box where the adjuster is this is stamped
CRTAAF
3580-A
attached some pictures
Thanks Stephen
Farrell In Vancouver 01-18-2018 12:45 PM
Re: Steering box Id.
Doesn't resemble any Model A or AA that I have seen
Chalkie 01-18-2018 12:50 PM
ill post some more pictures of the insides as well.
1930-Pickup 01-18-2018 01:33 PM
Never seen one like that.
jwilliams81 01-18-2018 01:40 PM
Seems someone else has had one too...
https://www.fordbarn.com/forum/showthread.php?t=128075
https://en.wikipedia.org/wiki/Ingersoll_Machine_Tools
Maybe Canadian:
https://www.ford-trucks.com/forums/1...ering-box.html
Mel Gross 01-18-2018 02:31 PM
Is your vehicle a right hand drive vehicle?
If so, the box looks very similar to a right hand drive F100 box.
Chalkie 01-18-2018 02:49 PM
Thanks for the replys. well spotted it it is a RHD steering box.
Chalkie 01-18-2018 03:42 PM
few more pictures of the internals and pitman arm
Chalkie 01-18-2018 03:50 PM
2 Attachment(s)
Pitman arm
jimvette59 01-18-2018 03:58 PM
That Pitman Arm looks made up. JMO.
Chalkie 01-18-2018 04:05 PM
2 Attachment(s)
internals
Chalkie 01-18-2018 04:06 PM
Thanks for all the reply's, appreciate the help I've been a contact for a guy who rebuilds and mods steering boxes so if I find out what it is I shall let you all know. unless anyone else responds thanks
