Radial tires Looking for some insight on the 19 inch radial tires for the model A. I read how good they make the car ride but a fellow in our model A club warned me about how the rims can crack when installing radial tires on bias ply rims. I wonder if the inner tubes may help stop the cracking and only applies to tubeless rims?
Thanks for your advice, Chris |
Re: Radial tires I might be missing something but I can't see why that would happen.
BTW, it not legal here to mount a tyre on a wheel without the safety ridges on the rim without a tube. |
Re: Radial tires 1 Attachment(s)
If your rims are in good structural condition you should have no problem.
In stock form, I do not think the weight of a Model A and cruise speed are enough to cause concern. The inner tube only serves to inflate the tire. The weight of the car is carried by the tires - Specifically the bead contact point. |
Re: Radial tires Quote:
Funny how things get repeated on and on without any research or thinking . "A fellow said " yeh sure. As stated ,IF a radial without a tube could be kept inflated on a non safety rim, a pothole could deflate the tyre instantly with no tube fitted when the bead blew off the outside seal. |
Re: Radial tires Thanks Dollar Bill. I found that same SEMA web site. Interesting read.
Re: Radial tires Concurrent to this topic, are radials not considered "overkill" on a vehicle that cannot travel at the speeds where the differences between the two types of tire designs can even be detected?
Bill |
That said, not all tyres are the same. Generally speaking, the cheaper brands of conventional tyre are worse than the dearer ones. |
Re: Radial tires We have the radial tires on the roadster pick up and friend has them on a 29 sedan and there have been no problems at any speed.
Re: Radial tires I just read a paper on the question. Here is the link to the paper on cast iron rims and radial tires.
https://www.sema.org/files/attachmen...el-Fitment.pdf I have Firestone (gum dipped) 19 inch and don't see a reason to change. I think radials would be unnecessary for me. |
Frank |
