The Ford Barn
-   -   Help with Brake Wedge ID (https://www.fordbarn.com/forum/showthread.php?t=236595)
BillCNC 01-05-2018 02:20 PM
1 Attachment(s)
Hey Guy's,
I pulled these out of my rear brakes a while back and forgot to post this earlier. They are quite different from the front's or the replacement's from the part houses.
Any clue as to what the reason was for the two part assembly, and who make them?
Regards
Bill
jw hash 01-05-2018 02:26 PM
Re: Help with Brake Wedge ID
they look to be part of Flat Head Ted`s brake floating set up. there should a jam nut on the out side.
BillCNC 01-05-2018 02:51 PM
Thanks a bunch jw.
It does have Flat-Head-Ted Setup's on the rears but no jam nut's were on the car and were just screwed in like the stock wedges.
Are they better than the stock ones? I do have an extra set to replace them with if they are inferior.
Regards
Bill
