The Ford Barn
-   Late V8 (1954+) (https://www.fordbarn.com/forum/forumdisplay.php?f=5)
-   -   template (https://www.fordbarn.com/forum/showthread.php?t=236415)
Milt/Las Vegas 01-02-2018 10:13 AM
template
Template needed for a 63 Galaxie 500 XL convertible rear seat belts.
Ole Don 01-02-2018 11:43 AM
Re: template
I would drill up from the bottom so as to not mess up what may be hidden. A small hole first, if it isn't right, put in a bolt and nut. I drilled down from the top once and ended up with nuts above the frame.
