Tire pressure for tires on a model A Ford Here in Europe when you pull into the Gas Station either for gas or Check the Air in your tires, Very close to $8.00 a gallon for gas, the air is free. Problem not the price of gas, but the measure of the air in Bar. Internet says 2.5 bar is over 36 lbs. Hard to get 2.4, which is below 35. OPERATORS Manual says 35 PSI. What do you recommend for the correct pressure of bar for my tudor 1930 Model A Ford. Normally run three to four adults in the car no load.
Re: Tire pressure for tires on a model A Ford 2.5 bar is fine for a cool tire. The air temperature and the tire temperature make the tire pressures vary a lot more than 0.1 bar.
Besides, the pressure on one gauge probably wont match exactly to the next gauge anyway. |
Re: Tire pressure for tires on a model A Ford I run 45 lbs (3.1 bar) on my 29, 21 inch wheels. Have for years. Catch lots of flack on it here every time I mention it but three reasons: 1- drives better, especially in a sidewind. 2- sidewalls don't squish as much 3- tires wear more evenly.
Re: Tire pressure for tires on a model A Ford I have always inflated my model A tires to 35 psi
Re: Tire pressure for tires on a model A Ford 1 Attachment(s)
I don't see a "BAR" listed as a measurement scale on the pressure gauge.
Would not one of these gauges take all the guess work out of it. Don't know how they measure pressure in Europe, never been there, they sent me the other way, during the "conflict" |
Re: Tire pressure for tires on a model A Ford On one of my modern cars cold pressure was 35 psi hot pressure 39psi, If you are driving to the station to fill the tires your 2.5 bars may be a little low!
Re: Tire pressure for tires on a model A Ford Quote:
A 4wd magazine here did brake tests with "reduced" tyre pressure. Commonly done here on rough roads. They found significant improvement in braking distance by reducing pressure. ie. it lengthens the contact patch. From a quick search: "Comparison of results shows that the vehicle had the longest stopping distance when the tires were inflated to 20% higher pressure than indicated by the vehicle manufacturer." http://article.sapub.org/10.5923.j.i...130202.01.html |
I'll leave that for your passengers after the 'incident' :eek: |
Re: Tire pressure for tires on a model A Ford Updraught posted: OK. Here is your flack this time: A 4wd magazine here did brake tests with "reduced" tyre pressure. Commonly done here on rough roads. They found significant improvement in braking distance by reducing pressure. ie. it lengthens the contact patch. "Comparison of results shows that the vehicle had the longest stopping distance when the tires were inflated to 20% higher pressure than indicated by the vehicle manufacturer."
It's very likely the article you cited were testing radial tires where bias ply tires will handle much differently. |
Re: Tire pressure for tires on a model A Ford Most tire manufactures suggest a range for inflating each type of tire. The range should be on the side wall of the tire. You're probably safe as long as you don't exceed the high
number. If you want to be right on 35 lbs., buy a U.S. tire gauge and a tire inflator. Since Ford built Model A's around the world, there must be an Owner's Manual written with metric values. We have guagues here in the U.S. with digital readouts. If you have a digital gauge with a digital readout in the metric system, that may solve your problem. If you have to use the gas station to fill your tires, have them use the high number and let out air out until your have the pressure you want using your gauge David Serreano |
Re: Tire pressure for tires on a model A Ford Mine say max PSI 45 lbs, that's right where I keep them.
Re: Tire pressure for tires on a model A Ford 35 lbs. here.
I don't know how that translates in metric. Give them time some clown will figure out a way to tax the air it won't be 'free' anymore:mad: |
The proper pressure, for ALL tires, is determined by several key engineering factors. One factor that engineers can't design in is the exact operating load that you will be placing on the tire. They can only specify a safety range, or 'max pressure' if you will. Why would anyone want to drive on tires that are at the very edge of the safety zone? The proper tire pressure will create a footprint ideal for traction, mileage, comfort, braking, and so on. It's up to the owner to take the operation of his/her vehicle into consideration in setting the right tire pressure. Does a near empty roadster place the same load on the tires as a full sedan?...of course not. It's a lot like oil viscosity for new cars. Rather than specifying different oils for different climate zones, today's car manufactures specify one type of oil for everyone. Makes life simple, but its a compromise. Compromise is what its all about...that's why Ford specified 35 PSI for the general public in Model A tires. |
Re: Tire pressure for tires on a model A Ford Thanks 1930 pickup .
Wonder how low you can go, before a forceful braking episode will spin the tyre on the rim and chop the valve off. |
Re: Tire pressure for tires on a model A Ford Only measure in bar here in Europe.
Re: Tire pressure for tires on a model A Ford 35 pounds
2.4 bar |
Re: Tire pressure for tires on a model A Ford If we had SOLID RUBBER Tires, there'd be NOTHING to talk about!
Bill Quiet |
