The Ford Barn
-   -   oil leak at center block bearing bolt (https://www.fordbarn.com/forum/showthread.php?t=234865)
barkleydave 12-07-2017 08:51 AM
Have oil leaking bearing center main bearing bolt. Any fixes without tearing it down. Sealants etc. It is not a huge leak just messy one.
Thanks
redmodelt 12-07-2017 10:18 AM
Re: oil leak at center block bearing bolt
You could try; Clean the area around the nut. Hook a vacuum cleaner hose up to the oil fill spout. With the vacuum on, work sealer around the base of the nut. With luck the vacuum will pull sealer into and voids. Other then that, it's drop the pan to fix.
This is a fix done by Model T people, and the T engine is a lot less air tight.
burner31 12-07-2017 11:07 AM
I've never heard of this method...But it's brilliant!
Them "old timer's" sure had the "American can do" attitude
BILL WILLIAMSON 12-07-2017 11:19 AM
Remember, it's NOT a pressure leak, it's just from SPLASH & CAPILLARY wicking.
Bill Sealerguy
