The Ford Barn
-   -   licence plate mounting on 32 high boy (https://www.fordbarn.com/forum/showthread.php?t=234732)
qmdv 12-05-2017 05:47 PM
Not sure how to mount my rear licence plate on 32 highboy. I put 48 Ford tail lights in the back panel and am pretty happy with them. Does anybody make something cool for the plate that mounts to the spreader bar.
TomT/Williamsburg 12-05-2017 06:04 PM
Re: licence plate mounting on 32 high boy
They make mounts for the front but I am not sure of the back. My avatar has it in/on the back panel.
TJ 12-05-2017 06:48 PM
They used to make some billet aluminum brackets that clamped to the spreader bar to mount the plate. Check places like Yogi's or Brizio Street Rods as they build a lot of '32 hotrods.
Karl Wescott 12-05-2017 07:52 PM
Basically a non-stock part, as the original license plate mounted to the RH taillight. So to parody a previous thread, the stock answer to a non stock question is to "go to hamb", but let not go there this time.
An easy way to mount the license plate on top of the spreader would be to use a front license bracket.
There are, or have been, several brackets produced... you would have to check all the billet and other street rod manufacturers catalogs.
On my roadster I could not find anything that I liked the looks of (I wanted the license plate centered to the spreader), so I fabricated one using muffler clamps. It works well and I like the look.
Have fun
RalphM 12-05-2017 09:23 PM
1 Attachment(s)
For the front I used stainless steel clamps designed for air hoses on a pogo stick on a truck.
My rears are not as fancy, I used plumbers tape :)
Ozyrodder 12-06-2017 06:42 AM
I used original hose clamps around spreader bar with a strip of rubber under each clamp.
Krylon32 12-06-2017 08:54 AM
On a vintage style deuce highboy nothing looks better than a Hollywood style license light and bracket mounted on the end panel between the taillights. There's one for sale on the HAMB for 20.00.
tomkowal 12-06-2017 09:22 AM
i agree with Kryoln32
qmdv 12-06-2017 09:55 AM
Do you have the link.
Tim
32phil 12-06-2017 09:57 AM
I mounted my rear plate on the back panel between a pair of 39 blue dots. The bracket has the license plate light built in.
Very traditional look and it keeps all the wiring inside the trunk.
qmdv 12-06-2017 10:05 AM
https://www.vintagetrailersupply.com...-p/vts-173.htm
Seems they are repro them for those that want to restore an old Airstream
Tim
TJ 12-06-2017 11:15 AM
Take a look at the stainless hangers used for lake pipes. Speedway has them and they might be just what you need.
Krylon32 12-06-2017 01:33 PM
Just go to the HAMB and click on parts and scroll down and you'll see it, he actually has 2 listed.
34pickup 12-06-2017 02:02 PM
1 Attachment(s)
I made my own brackets to mount this one on mine.
RalphM 12-06-2017 03:16 PM
1 Attachment(s)
My rear plate is temp mounted, plan on putting one of those Hollywood light/ plate mounts on mine as well. As soon as I get a round tuit.
I put 42 Oldsmobile lights on my back panel, plate will go between.
Randy in ca 12-07-2017 03:36 AM
Is a light to illuminate the rear plate not required in Al.?
ct1932ford 12-07-2017 09:45 AM
1 Attachment(s)
My coupe! Plain and simple sometimes is better.
Attachment 341547
34pickup 12-07-2017 10:50 AM
Yes it is. After I posted this I realized this photo was taken before I put the light on. I now have a license plate light that mounts above the tag. I don't have a photo of it.
outlaw 12-07-2017 11:08 AM
Attachment 341547
This is classic! https://www.fordbarn.com/forum/images/icons/icon14.gif
qmdv 12-07-2017 11:37 AM
Much help received on this forum. Thanks. Just ordered the Hollywood plate holder.
