The Ford Barn
-   -   Rebuild kit 221 (https://www.fordbarn.com/forum/showthread.php?t=234654)
W1964 12-04-2017 04:06 PM
Rebuild kit 221
Anyone have ideas for source for a rebuild kit for a 221? Best we can find is over $2600 from Egge. That sounds a little high! Your thoughts please. Bill
lotsagas4u 12-04-2017 04:33 PM
Re: Rebuild kit 221
Wish I could find a rebuilder in Texas
Seth Swoboda 12-04-2017 04:42 PM
Re: Rebuild kit 221
Just for parts like valves, Pistons, bearing, gaskets, rings, ect......? Call Van Pelt Sales or Michael Driskell at Third Gen Automotive. Both guys are here on the barn.
W1964 12-04-2017 05:51 PM
Re: Rebuild kit 221
Thanks for your help. I cannot locate Third Generation Automotive. Do you have his contact info?
Thanks again.
Bill
deuce_roadster 12-04-2017 06:01 PM
Re: Rebuild kit 221
You might list what parts are included for $2600. If it was everything I would replace it doesn't sound out of reason. I've never rebuilt a flathead in the last 5 years with machining that was less then 4k. I realize work costs less in different parts of the country.
51504bat 12-04-2017 06:28 PM
Re: Rebuild kit 221
Try Red's Headers in Thousand Palms, CA
www.reds-headers.com
31410 Reserve Dr #4, Thousand Palms, CA 92
(760) 343-2590
W1964 12-04-2017 06:33 PM
Re: Rebuild kit 221
Understand that is parts only. No machine work. Same kit for a 239 can be bought for $900.00 my rebuilder tells me.
Brian 12-04-2017 09:26 PM
Re: Rebuild kit 221
W1964, exactly which 221 are you rebuilding? There is three basic versions.
W1964 12-04-2017 10:12 PM
Re: Rebuild kit 221
Frankly, Brian, I don’t know. It’s an 81A if that’s the answer. My Coupe is titled as a 1939 Deluxe. I find so many things common to a 38, I call it a 1938 1/2. It definitely is an early 39 based serial number. Tell me what specifically to be looking for, please.
Brian 12-04-2017 10:50 PM
Re: Rebuild kit 221
81A, cool! Next questions for a positive id, how long [roughly will do] is the crank snout? Where the front pulley attaches. Single pulley sheave or two? If single, does the boss extend forward of the pulley?
Brian 12-04-2017 10:52 PM
Re: Rebuild kit 221
81A version of the 221 will be the cheapest to buy parts for.
Mac VP 12-05-2017 07:00 AM
Re: Rebuild kit 221
Suppliers tend to sell different packages of “engine kits”. We decided some time ago to just put together the group of parts that is specific to the customer’s engine......and his/her specific parts request. Plus, there are price variances in bearings for example. I can only imagine what someone would get for only $900 worth of flathead engine rebuild parts.
Pistons, rings, main bearings, rod bearings, cam bearings, all the various valve components, timing gears, oil pump, overhaul engine gasket set.......and all the various other bits and pieces that may be necessary. Obviously, you would need to know what the finished bore size will be, and the finished crank journal sizes will be.
Will you want adjustable lifters? How about water pumps, carburetor, fan belts, starter, new studs or head bolts, etc. many things can go into a rebuild package. This is why we figure out things with our customer and then build a specific package for him which we discount as a group. Just how we do it.......
Bored&Stroked 12-05-2017 09:07 AM
Re: Rebuild kit 221
I think the most important thing is to first figure out what you NEED to buy - versus what can be reused. Also, depending on the condition of what you have and the experience/skills of your rebuilder, the parts list and specific combination of parts can change dramatically. Hopefully you have a rebuilder who is experienced in flatheads, has the necessary equipment (some of it is specialized - especially in the valve train area) - and knows how to use it. Once you know what you have and what can be reused, then talk to Mac, Red's Headers, Third Gen, etc. . . I'd stick with ONE supplier for everything - and not mix-match components from all over (since you're new to this).
Feel free to PM me once you have your ducks in a row - be happy to provide some perspective to what you're undertaking and things to potentially think or be aware of.
Best of luck and it is FANTASTIC that you're bringing an old engine back to life! :)
JSeery 12-05-2017 10:43 AM
Re: Rebuild kit 221
Be sure your remember that is Mac VanPelt! :)
Bob C 12-05-2017 11:20 AM
Re: Rebuild kit 221
Thanks again.
Bill
He goes by 35fordtn on this board. [email protected]
Bob
Seth Swoboda 12-05-2017 01:49 PM
Re: Rebuild kit 221
Thanks again.
Bill
2600 Old Nashville Hwy
McMinnville, TN 37110
(844)327-5988
[email protected]
Krylon32 12-05-2017 02:15 PM
Re: Rebuild kit 221
For the last couple FH's I had built I sourced the majority of my parts from Baxter Ford Parts in Lawrence Kansas. Good quality parts.
Seth Swoboda 12-05-2017 02:30 PM
Re: Rebuild kit 221
They are good folks as well. Thanks for mentioning them.
mfirth 12-05-2017 03:28 PM
Re: Rebuild kit 221
w1964, i have seen kits on e bay from $1200-$1700, check it out. I'd want to know who makes the components though.
W1964 12-07-2017 11:19 AM
Re: Rebuild kit 221
Thanks to all for good advice. I was able to order parts Al a carte from Van Pelt and Joe's at considerable savings from the quote from Egge. We are fortunate to have Van Pelt and Joe who specialize in Early Ford parts. They are great people to work with - like the good folks on this forum.
