The Ford Barn
-   Late V8 (1954+) (https://www.fordbarn.com/forum/forumdisplay.php?f=5)
-   -   55 Club Sedan motor mounts (https://www.fordbarn.com/forum/showthread.php?t=234023)
Tombstone 11-26-2017 07:48 AM
Hi everyone,
I just joined and am happy to see such a great amount of information available. I recently bought a 55 Club Sedan that had been converted to a 302/c-4. The guy that did the work obviously didn't possess the same set of standards that I do. I've since done a lot of changes, repairs and upgrades but need to replace the motor mount rubber. The 302 fits nicely but the old engine mounts were reused and I'd like to replace them. Any help would be appreciated.
Thanks,
Jeff
KULTULZ 11-26-2017 09:20 AM
Re: 55 Club Sedan motor mounts
Hard to say how he did the conversion...
Might have to pull a mount (sit engine back down on frame mount on a 2 X 4) and inspect it.
Please watch your fingers... :eek:
paul2748 11-26-2017 09:02 PM
If the mounts are stock Ford they could be either of these;
84 Lincoln Mk VII Anchor 2725 and 2726
or
1976 F150 302
The rubber is not replaceable, you have to change the whole mount.
I don't have any experience with these, but is info I picked up from various sources.
triumphleroy 11-27-2017 09:14 AM
Seems like I remember someone else talking about these mounts and maybe you switch sides with them to use in when swapping from Y Blocks?????
KULTULZ 11-27-2017 01:29 PM
GO HERE - http://www.hotrodders.com/forum/55-f...wap-83526.html
And scroll down to POST #8
63/64 FORD 289 mounts will work wit a 1" spacer.
paul2748 11-27-2017 09:18 PM
With the Lincoln mounts, the spacer is not required so I am told. The are supposed to be i inch taller than the other mounts.
KULTULZ 11-28-2017 11:12 PM
Sounds good to me. I am still in the mid-sixties... :rolleyes:
Tombstone 11-29-2017 12:00 PM
Great information, thanks
JeffB2 11-30-2017 03:15 AM
Originally Posted by Tombstone (Post 1557237)
Hi everyone,
Thanks,
Jeff
Pictures tell a story,text with part numbers are here too. ;) https://www.jalopyjournal.com/forum/...-mounts.41498/
KULTULZ 11-30-2017 07:23 AM
Hey Jeff...
What engine mount is pictured below? -
https://www.jalopyjournal.com/forum/...l?d=1399664536
Is this the FORD C3AZ 6038-G & H (or aftermarket 63/64 FORD 260/289)?
It shows no spacers used... :confused:
JeffB2 12-02-2017 01:20 AM
Originally Posted by KULTULZ (Post 1558956)
Hey Jeff...
These are what they are scroll down to the part numbers,same at O'Reilly's or Autozone's Duralast https://www.ebay.com/itm/2-PCS-FRONT...!US!-1&vxp=mtr
JeffB2 12-02-2017 01:23 AM
These can be swapped side to side one way is forward the other way closer to the firewall (this helps with a C4)
KULTULZ 12-02-2017 09:06 AM
THANK YOU!
Nice to know... ;)
JeffB2 12-02-2017 04:18 PM
Originally Posted by KULTULZ (Post 1559854)
THANK YOU!
Nice to know... ;)
The transmission mount used in this swap is this one,click on the part number in blue to see the applications: http://www.rockauto.com/en/parts/anc...ion+mount,8616
KULTULZ 12-02-2017 06:45 PM
And that will allow the C4 to sit correctly on the original trans cross-member (considering the engine placement is correct)?
If so it makes for a clean swap.
THANX!:D
JeffB2 12-04-2017 01:40 AM
1 Attachment(s)
Actually the AOD is better fit than the C4 it's mount distance is exactly the same as the Ford-O-Matic or 3 speed stick. Here is a picture of my own AOD on the stock trans cross member in my '54. With either a C4 or AOD you can use a 1982-86 Crown Vic drive shaft with a NEAPCO 2-0291 conversion U-joint and it will bolt right up to the stock rear end.
JeffB2 12-04-2017 01:44 AM
1 Attachment(s)
Here is a 1953 Ford using the Butch's 15'' kit with a 302 & AOD (the same mount is in their kit) & same drive shaft.
JeffB2 12-04-2017 01:50 AM
The chart here shows the difference in mounting distances (measurement "C") http://non-stoptransmission.com/en/info-ford.php This is why you may have to play with a C4 just a bit about 2".
KULTULZ 12-04-2017 03:19 AM
How is your AOD performing? Is your conversion a driver or performance, carb'd or injected??
THANX for that chart!
JeffB2 12-05-2017 04:33 PM
Mine is a .040'' over 302, heads are 289 Hi-Po with mild Ford Motorsports hydraulic Cam same specs as this one: http://www.lunatipower.com/Product.aspx?id=3061&gid=338 Intake is a Professional Products Typhoon with a 625 CFM Carter Competiton Series AFB Hedman 88400 headers.Since mine had the 3 speed overdrive rear gears are 4:10's if you run an AOD with anything steeper than 3:55's you need this:https://www.summitracing.com/parts/trg-aod-hirev or it upshifts too quick at lower speeds. She is just a driver if i was to beat on it a rear end swap would be in order.
