The Ford Barn
-   -   How to remove horn ratchet? (https://www.fordbarn.com/forum/showthread.php?t=233229)
burner31 11-13-2017 11:52 AM
1 Attachment(s)
I want to clean up a original Stewart/Warner Model A Horn, but can't get the nut off the ratchet so I can pull the armature out.
Lefthand or righthand threads?
And how do I hold the armature while removing the nut?
I don't want to mess things up, so I'm asking...how do you get that dang thing off without destroying the whole thing?
SeaSlugs 11-13-2017 12:03 PM
Re: How to remove horn ratchet?
i believe its a left hand thread. There may be 1 or 2 threads sticking out that you can closely examine. They typically arent stuck very hard - soak in some kroil or PB blaster or something for a day or so. Ive used a soft towel around the armature core (not the brush area) in my hand and a box wrench on the nut. You dont want to risk damaging anything on the armature so i wouldnt use any tools just your hand and a towel to protect your hand.
Whatever you do dont force it - i think theres one horn maker out there that uses standard right hand threads...
Kevin in NJ 11-13-2017 12:58 PM
Left hand threads!!!!! The SW horns use left hand threads and yes the stud does break easy if you go the wrong way.
Yes, I learned how to make left hand threads on my lathe.
Bill G 11-13-2017 02:06 PM
I join the crowd. Left hand threads!
Bill G 11-13-2017 02:17 PM
One more thought....I would say that the best way is to leave it alone.
Even after I boogered it up by wrenching the nut off, I still went ahead and tried to clean up the armature shaft where it goes through the bushings at each end to make it spin more freely. After all that, I did not accomplish much.
Wishing now I had just lubricated it without messing with it.
Years ago I worked in a Hi Fi shop and took many motors apart for repair. Mostly AC induction motors, but some DC motors. The motor in the Model A looks alarmingly simple and one would think it would be an easy dis-assemble and re-assemble. For the most part, yes, but that dang left-hand thread really soured me on the whole idea of rejuvenating the horn.
Proceed with caution.
30ccpickup 11-14-2017 05:52 AM
I use a screwdriver to hold the armature by gently placing it between the outer metal parts of the motor and leaning it against the bracket.
Here is a simple tune up
http://modelabasics.com/horn.htm
burner31 11-19-2017 02:16 AM
Got the horn working good now.
Used the horn tune-up from "30ccpickup" post 6...thank you
and I put in a new diaphram and some gaskets that were not in the horn when I got it.
Also installed the horn relay, all together it worked a miracle.
If your horn is dragging and weak I would recommend the horn relay, PITA the hook up but well worth it.
Thank You All
