The Ford Barn
-   -   C4 transmission (https://www.fordbarn.com/forum/showthread.php?t=228489)
michael a 09-05-2017 08:26 PM
C4 transmission
Have any of you use the speedway kit what did you think of it
Sent from my SM-J700T using Tapatalk
George/Maine 09-06-2017 08:41 AM
Re: C4 transmission
The c4 trans have 2 bellhousing large and small both 6 bolts.
Count the teeth on torque convetor and order cerrect one.
They work very good little grinding to clear oil pan and starter.
A stock torque convertor will work best. A locar shifter works good.
Krylon32 09-06-2017 10:06 AM
Re: C4 transmission
I have done several in the customer chassis I build with no negative feedback except the grinding as stated above.
Ol' Ron 09-06-2017 02:17 PM
Re: C4 transmission
I think that kit will allow you to use the AOD trans, which has an Overdrive. This way you have much better acceleration, and economy as well.
paul2748 09-06-2017 07:51 PM
Re: C4 transmission
I have a Flat-O kit behind a Yblock and it has worked out very well. Been on about 5 years. Directions are good, pieces look well made.
I know a couple of other who put a Flat-O kit behind a Yblock and so far all is well.
TJ 09-06-2017 07:54 PM
Re: C4 transmission
I've used the Flat-O-Products kit and was very satisfied with it. Easy to install and I used a mini starter with it.
