The Ford Barn
-   -   Big guy (https://www.fordbarn.com/forum/showthread.php?t=228366)
michael a 09-04-2017 10:09 AM
Big guy
What can you do to get more leg room in a model a sedan I have move the seat back and that helped a bunch but it seems like I need more leg room can I raise that seat and get it what are you big guys do to be comfortable inside your model A
Sent from my SM-J700T using Tapatalk
BILL WILLIAMSON 09-04-2017 10:16 AM
Re: Big guy
Michael,
This has ALWAYS been a problem for some.
I'm CURIOUS, if we'll get any NEW ideas.
A Friend NEVER put a roof in his Coupe, for BIRDS, he carries a BIG folded cardboard & a BRICK!
Bill Notmuchhelp
Dodge 09-04-2017 10:59 AM
Re: Big guy
In my Tudor Sedan I bought the seat brackets from Snyders that move the seat back and it's very comfortable now. Did you use those?
1931 flamingo 09-04-2017 03:07 PM
Re: Big guy
My tudor seat was moved back when I got it. Simple angle iron bolted to the floor with several holes about 1" apart. I modified it to raise seat about 3". Easily returned to original.
Paul in CT
Fred K-OR 09-04-2017 05:00 PM
Re: Big guy
Don't know if your problem is when you are in the rig or when you are trying to get in. With my 29 coupe, getting into it is my problem. The way I get in is to put my right leg in first, put my buns on the seat and then pull my left leg and big foot in. Not the most graceful but it works. Also moved the bottom of the seat back a few inches.
michael a 09-04-2017 08:00 PM
Re: Big guy
My problem is really both I basically get in the same way you do but I have seat other than stock how far from the floor to the seat bottom should my seat set
michael a 09-04-2017 08:01 PM
Re: Big guy
No sir I didn't but I will look at them and thank you guys for all your help
