The Ford Barn
-   Late V8 (1954+) (https://www.fordbarn.com/forum/forumdisplay.php?f=5)
-   -   Early Mercury with a y-block (https://www.fordbarn.com/forum/showthread.php?t=227357)
Noswal 08-21-2017 06:08 PM
Anybody ever put a y-block in a '46-'48 Mercury? Is there interference between the distributor and firewall?
TJ 08-21-2017 07:16 PM
Re: Early Mercury with a y-block
The 42-48 Mercs have a long engine compartment due to the 4" longer wheel base. Should not be a problem to install a Y block or later 302 or 351 Windsor. Lots of area to move the motor forward if needed.
Noswal 08-22-2017 04:24 PM
Thanks TJ. Hoping for a painless installation.
skidmarks 08-22-2017 06:35 PM
Using the stock transmission? The only interference is the oil filter, exhaust can be tricky. On a ford of that era the oil pan needs notched in the very front. The distributor will clear the firewall.
