Carburator Throttle Plate Question Is the Throttle Plate ever completely closed without any clearance between it and the body ?
Re: Carburator Throttle Plate Question My carb has a small gap when the idle screw is set correctly. If the plate is totally closed, I don't think the car wouldn't idle.
Rusty Nelson |
Re: Carburator Throttle Plate Question No, not really. But part of rebuilding a carburetor includes backing off the idle speed screw and checking/adjusting the throttle plate for proper fit.
Re: Carburator Throttle Plate Question I agree but with out the set screw not set the throttle plate must fully close with a goog fit ,if you look up toward a light you should not see any light bleeding threw if you do the throttle plate is not seated correctly
Re: Carburator Throttle Plate Question When installing a throttle plate in a Zenith, I back off the idle adjust screw and loosen the two small plate screws. Then I open and close the throttle smartly several times. This will center the plate in the throat of the carburetor. There is enough play in the plate screws to allow this. Then while holding the plate closed I tighten the two plate screws. The idle adjust screw is then run in to open the plate until the small idle hole in the throat of the carburetor is split by the plate. This will allow for the engine to start up at a high idle. The idle screw can then be adjusted for the desired idle speed.
The engine will not run if the throttle plate is fully closed. Tom Endy |
Re: Carburator Throttle Plate Question Thanks to all for the comments. Will finish rechecking and cleaning my carburetor in the a.m.
Re: Carburator Throttle Plate Question Quote:
