The Ford Barn
-   -   brake cross shaft (https://www.fordbarn.com/forum/showthread.php?t=226852)
mrwarm 08-15-2017 09:35 AM
brake cross shaft
tried to set brake cross shaft arms in the middle but one arm is tilted forward and the other arm is tilted back. nothing is loose or seems worn. is this normal?. having hard time setting brake rods
Art Newland 08-15-2017 10:59 AM
Re: brake cross shaft
Mines a bit that way too...:confused:
frank55a 08-15-2017 11:05 AM
If you have the 3 piece 28 center brake shaft perhaps your 2 outside shafts are on the wrong sides.
mrwarm 08-15-2017 12:19 PM
I have a one piece shaft. 29 sport coupe
