Time bomb? I have a 10-leaf spring from an old project leaning against the inside wall of my garage, with the center bolt in place. Is this a ticking time bomb? Should I (carefully) disassemble it? Ignore it?
Re: Time bomb? Do you carry life insurance?
If so, your survivors will be taken care of. Bob |
Re: Time bomb? Maybe just wrap some chains around it just to be sure that center bolt does not let go and take out your and a wall. Or to get rid of all the risk, disassemble-very csrefully.
Mike |
Re: Time bomb? Is the spring any good?
If questionable, take to scrap yard. Have you ever seen a 90 year old chair that an over weight person has been sitting on for 90 years? |
Re: Time bomb? Front or Rear?
If it's a rear spring follow the advice given..! |
Re: Time bomb? If it is a rear spring it is dangerous if mounted in shackles on a differential. It is in a relaxed state if not, and shouldn't worry you.
Re: Time bomb? It should be fine if the spring or bolt is not rusted badly. Rear springs are very powerful, but the bolt should hold OK. I have 3 rear springs setting in my barn and nothing has happened for many years. If you really are nervous, take a medium to large C clamp and clamp it next to the bolt.
Rusty Nelson |
Re: Time bomb? Im not sure what you are worried about??. A spring pack just leaning against a wall or lying on the floor has very little energy stored in it since the leaves are pre bent before assembly. They do have SOME energy as they do have a preload on them but it's not a lot. I've never played with Model A rear springs but I have a few lying around. They could be different but I would be surprised.
Re: Time bomb? Quote:
Re: Time bomb? Isn't 10 leaf a front spring? I agree with #9. Wear steel toed boots or lay it flat. If it is a rear then there is some stored energy, but I wouldn't worry too much. Put a C clamp or two on it if in doubt.
