The Ford Barn
-   -   Ford Stromburg 94 Carb rebuilding (https://www.fordbarn.com/forum/showthread.php?t=225943)
Vics Stuff 08-02-2017 11:46 PM
Hey Guys who would you recommend on having a Ford Stromburg 94 Carb completely rebuilt. I want the body re colored and the shafts and bushings repaired. I do not want a wash and reassembled carb. I can do that myself. Just want this to be like new ?
I have a original 35 Pick up with the Flathead V8 and want to keep it all stock.
Thanks Vic
34fivewindow 08-03-2017 01:33 AM
Re: Ford Stromburg 94 Carb rebuilding
Thanks Vic
35 ford should have a Stromburg 48 carb on it.
scicala 08-03-2017 10:05 AM
I think you have the carb model wrong as 34fivewindow said.
Holley was never in collaboration with Stromberg. The '94 is a Ford/Holley shared carb that was used on flathead V8's from '39 and up.
The best guy to do what you want is Uncle Max (if a Stromberg) or Charlie NY if a Ford Holley 94.
Sal
Vics Stuff 08-03-2017 10:38 AM
Ok Guys. I could be incorrect in assuming that my truck is completely original. There is a #94 stamped on the carb body and assumed it was a Stromburg 94. it is whats on my truck currently.
How do I get in touch with uncle max ?
Thanks Vic
corvette8n 08-03-2017 11:03 AM
Stromberg made #97 carbs ford/holly made the #94
Charly NY rebuilt my 94 and my car runs great
His contact is below
https://www.fordbarn.com/forum/member.php?u=1147
Just private message him he will get back to you.
Unless you have owned your vehicle from new, you don't know who put what carb on it.
Dave Castle 08-03-2017 11:23 AM
Recarbo in Pittsburg ca., has done a number of carbs 4 me, happy with all of them.
flatjack9 08-03-2017 12:10 PM
To be clear, you do not have a Stromberg carb.
FlatheadTed 08-03-2017 02:47 PM
Stromberg carb. is a better carb in my opinion ,you don't have the leak down problem from the power valve ,the outlet is above the float level ,Ted
flatjack9 08-03-2017 05:26 PM
Personally, I think the 94 is a better carb.
Vics Stuff 08-04-2017 12:11 AM
Here are some pics of the carb.
I tried to post from my phone but not successful.
On the left side there is a model #59 casted on the float bowl and the #94 is just above the center intake mounting stud. SO what do I have ?
Thanks Guys
Vic
34fivewindow 08-04-2017 01:01 AM
Thanks Guys
Vic
1946 - 48 ford or merc ford / Holley model 94.
Vics Stuff 08-04-2017 10:50 AM
Thank you 34fivewindow that is what I thought.
Vic
deuce lover 08-04-2017 01:02 PM
Thanks Vic
[email protected]
scicala 08-04-2017 01:35 PM
Uncle Max is the Stromberg expert. He may do 94's too. Not sure.
Charlie NY is the 94 expert.
Sal
Charlie ny 08-04-2017 02:27 PM
Vics,
The boss and I just got back into town, I got your PM and answered it
but here goes: my #'s are 716 662 9159 home
716 440 8952 cell
Thanks,
Charlie ny
Ol' Ron 08-04-2017 02:40 PM
personally I think the 94 is a better carb. However, you need a Stromburg 48 and Uncle Max is the place to go.
tubman 08-04-2017 08:37 PM
I'm another "CharleyNY" backer; I have had distributors and carbs done by him, and everything turned out perfect. Plus, he turns this jobs around in a reasonable time. Highly recommended.
Vics Stuff 08-04-2017 09:29 PM
Thank you Charlie. Will be getting in touch with you tomarrow on the details.
Thanks Vic
Vics Stuff 08-04-2017 09:35 PM
Did send MadMax a e mail also. Will see what can be done.
Thanks for the input guys.
Vic
Ol' Ron 08-05-2017 09:51 AM
Learn sumpin every day, didn't know Charley did Stromburgs. Getting old, brain has a few blank spots.
