6 Volt coil I need a new 6 volt coil. Is there a US. made coil?? jack
Re: 6 Volt coil To fit what??
Re: 6 Volt coil NAPA IC-12 Echlin 2.1 ohms primary, 8.9 ohms secondary. For 6 or 12 volt systems
NAPA IC-27 Echlin 2.2 ohms primary, 6.38 ohms secondary, for 6 or 12 volt systems |
Re: 6 Volt coil I would find a 46 to 48 coil, Have Skip rebuild it and mount it
on the head with a 46 coil bracket. You will need a 32 to 48 resistor. G.M. |
Re: 6 Volt coil Quote:
Re: 6 Volt coil The shoe box Fords came with a can type coil. Is this for a shoe box 49/51 Ford? If so, JSeery is pointing in a good direction. With 6-volt, no ballast is needed. When running 12-volt, a ballast resistor would be required.
Re: 6 Volt coil Just another option. I have been buying all the reasonably priced Mallory coils (6 and 12 volt) that I can find. I have checked them all out and they have all tested good but one, and that one was a "Magspark" unit. I sent three of the cleanest ones to Skip to be tested more rigorously, and he said they were all good to go. I'm an 8BA guy and like to run old Mallory dual points so the coils fit right in. I've never had a problem with any I have run. I prefer "The Best Coil I Ever Made", but they have gotten right spendy over the last couple of years. Lately I have been finding the "FlashFire" coils for less than $10. They fit in with the look I am going for. Just remember the black ones are 6 volt and the red ones are 12 volts.
