The Ford Barn
-   -   1933 Horn Sound? (https://www.fordbarn.com/forum/showthread.php?t=225218)
mike33ford 07-22-2017 04:52 PM
1933 Horn Sound?
Dear Ford Friends,
I am restoring a 1933 Roadster and was wondering what the horn should sound like? For those that have a 33 Ford, does the horn have the Ahoogah sound (like the 28-31 Model As) or the beep sound? Thanks very much for your help.
Mike
petehoovie 07-22-2017 05:08 PM
Re: 1933 Horn Sound?
At the three minute and 56 second mark in this video link below, they sound the horns. This is the correct sound for these horns. The two horns are adjusted to different tones from one another to get this correct sound when both are working in unison. I'm pretty sure the horns on both the '33 and '34 make the same sound....
https://www.youtube.com/watch?v=jdxEpb2cUPM
rotorwrench 07-22-2017 05:15 PM
The motor driven horns have the Klaxon or Ah-oo-gah sound. The small motor turns a ribbed disc in contact with the diaphragm to make the sound. The 1932 model year was the last of the Klaxon types for passenger cars. There were stragglers in the trucks for a year or two.
In 1933 they began using an electric vibrator coil in contact with the diaphragm to make a solid tone report. Some are high pitch note and some are low pitch note to get a dual horn harmony sound. Many of the early V8 Fords were standard models and only had one horn. The Deluxe models had the dual horns.
PS: Dual horns have different vibrator diaphragms for high and low notes. You can't adjust the pitch of the output tone but the harshness can be adjusted out for a more mellow quality.
mike33ford 07-22-2017 05:47 PM
Thanks very much for your replies. This is very helpful!
Barn Junk 07-22-2017 06:44 PM
Actually, the deluxe, 2nd right side horn when added on the 1933 and up cars/trucks, has a small cup shaped weight added to the diaphragm assembly to change the sound.
DavidG 07-22-2017 06:53 PM
With respect, the vibrator horn replaced the motor-driven horn on '32s about mid-model year, including commercial vehicles and big trucks.
rotorwrench 07-22-2017 07:06 PM
So that's why the diaphragms were interchangeable from the 1932 model year. I learn something new all the time. I didn't figure it would interchange with a Klaxon type. Too much difference. I just know that I've seen 1932 cars with them.
There is a lot of info in the parts books but obviously not near enough info. They tend to reflect the changes and not the originally issued parts.
mike33ford 07-23-2017 11:28 AM
Thanks again -- any recommendations where I can find interior horn parts? I have checked Macs, Speedway, etc. and do not see any horn parts.
DavidG 07-23-2017 01:43 PM
The centers (operating portions) of the two horns are basically the same through '37 and it may prove cost effective to find working versions of the later ones to replace what you have, retaining the bell, cover, and mounting bracket of your existing horn(s).
Mart 07-23-2017 01:55 PM
I expected the horns on the car in the video to make a good parp or loud beep sound. They sounded most peculiar to me. Is that really what they are supposed to sound like?
Mart.
Newc 07-23-2017 02:39 PM
Hi all; For you fellows using 12 Volt and Vibrator horns... A RG 9 member just converted his '33 dual horns with High/low vibrators from HARBOR FREIGHT. They fit on the original plates and worked excellent.. even tunable! Newc
Ken Arms 07-24-2017 12:38 PM
I have a post here on the barn showing a VW horn I fitted to an original spartan 34 horn. I think the beatle sound is close. Ken
rotorwrench 07-24-2017 12:46 PM
Mart.
I agree. It sounded sort of harsh or sickly to me. Some adjustment or service might be needed on that particular car.
weemark 07-24-2017 01:02 PM
I googled low and high vibrators :eek: but I couldn't find anything I could use in my horns...
rotorwrench 07-24-2017 01:10 PM
He may be referring to the guts removed from a regular set of horns. The horns I see on the Harbor Freight site look to be the 12-volt types.
I've used guts from old Delco and Motorcraft horns to fix a few old ones before.
Big-Foot 07-24-2017 10:40 PM
Got a link to that?
I'm very interested in updating a couple of Sparton horns for my 33. Actually, I only have one right now and its in sorry shape. I'm in the process of Delux-ifying my 33 Tudor Standard.
Lawson Cox 07-25-2017 09:02 AM
Will that work on a 6V?
FrankWest 07-25-2017 10:19 AM
1933 original horn sound
https://www.youtube.com/watch?v=JdHhR98jVAO
Big-Foot 07-25-2017 12:36 PM
Originally Posted by FrankWest (Post 1504209)
Thanks Frank - that's more like what I thought I remembered...
petehoovie 07-25-2017 12:41 PM
One Horn? Sounds to me as though just one horn is sounding in that video....
