The Ford Barn
-   -   Banjo rebuilders (https://www.fordbarn.com/forum/showthread.php?t=224918)
1oldtimer 07-17-2017 08:18 PM
Banjo rebuilders
Wasn't there someone in Southern California that had a service to rebuild banjo rearend?.
zzlegend 07-17-2017 08:35 PM
Re: Banjo rebuilders
You might try Richard Lacy here.
http://www.earlyv8garage.qpg.com/
Charlie Stephens 07-17-2017 08:49 PM
What year? If it is early '32 you might try Tom Endy since he is the Model A rear end expert and they are basically a Model A rear end.
Charlie Stephens
1oldtimer 07-17-2017 09:06 PM
It's a mix of parts. But it's a '47 truck center with '36 bells. I need pick someone's brain or have setup the pinion and side bearing preload.
zzlegend 07-17-2017 09:36 PM
As Charlie said, Tom Endy is the guru on model a rear ends. See if this helps you at all.
http://www.santaanitaas.org/wp-conte...vised-2014.pdf
Tim Brown 07-17-2017 10:59 PM
The Hot Rod Works in Idaho might be of help.
RobR'35 07-18-2017 05:16 AM
That's the best artical/write up I've seen on rebuilding rear ends for our cars.
I used it on my rebuild of a '46-'48 rear axle.
