The Ford Barn
-   -   Where do you store the cranckhandle? (https://www.fordbarn.com/forum/showthread.php?t=224507)
René W 07-12-2017 08:14 AM
In my tudor is no space to store the crankhandle and jack so i put it behind the seat on the floor.
If my trunk is on the rack i can put it there but the trunk is not always on,only when i go on long runs without a trailer.
Where do you put the crankhandle and jack,tools etc.?
JOHN CT 07-12-2017 08:35 AM
Re: Where do you store the cranckhandle?
What's wrong with under the rear seat :confused:
It's not like you use it every day.
1930artdeco 07-12-2017 08:35 AM
I though that the Tudor tools were kept under the rear seat? I store mine either in the trunk or under the front seat in my car.
Mike
abachman3 07-12-2017 08:57 AM
My crank handle is kept under the drivers seat in my tudor. The jack etc. is under the rear seat.
CB919ER 07-12-2017 09:09 AM
I have a jack under the front seat and I found the crank in the floor next to the rumble seat. I'll probably keep both under the front seat.
JDupuis 07-12-2017 09:13 AM
I keep the hand crank in a handy location. Under driver seat, or on floor in rear seating area. I am prone to drive a couple hundred miles at a time. Thus, I feel the need for a quick re-torque of all the wheels just in-case. I have the original tool pouch for each of my 5 model A's. I try to store the tool pouches under the rear seat, but I also keep a "travelling" tool box. That I take from car to car just in case. This travel tool box keeps my tuning tools, rags, bulbs, gloves, reading glasses, spare whatevers ect......
The trunk on the back of the tudor and the roadster are a godsend when travelling with friends in the cars. The biggest challenge I usually find is where to store the jug of coolant, so it doesn't tip over.
Jeff
Franchise_24 07-12-2017 09:43 AM
My crank handle is under my front seat.
Fullraceflathead 07-12-2017 10:34 AM
Mines under my seat in my Roadster Pickup
lindy williams 07-12-2017 10:37 AM
On most models there is room under the front seat. On a tudor there is room under the rear seat.
iverson 07-12-2017 11:21 AM
My uncle told me when he was a kid he saw a lot of fights were cranks were used so they must have had them handy! Tough for the T driver
Big hammer 07-12-2017 11:32 AM
Under the rear seat in a tudor ! Just push the lower cushion back, then lift up. If you shocks aren't working, put some padding in there ! :-) Points, plugs, rotor, cap etc, no room for a starter or generator. Someone makes boxes that under the pan under the rear seat, but you have to cut two big holes each side of the drive shaft :-(
RawhideKid 07-12-2017 12:17 PM
In my Tudor the crank is under the drivers seat and the jack is in my back pocket.
denniskliesen 07-12-2017 12:26 PM
The Tudor basement goes in front of the rear seat where the wood floorboard is.
http://www.snydersantiqueauto.com/storage-box
Big hammer 07-12-2017 12:30 PM
Thanks for correcting me !
CHuDWah 07-12-2017 12:30 PM
Doesn't that make sitting kinda uncomfortable? ;)
I stored tools under the seat - small stuff in the pouch and crank and jack wrapped in shop rags to keep from rattling (also good for wiping hands). Course that was a coupe that had a handy under-seat pan for the purpose. How about a toolbox on the running-board? More common on Model T but should work on A - don't think they're reproduced but original examples aren't too uncommon.
DougVieyra 07-12-2017 12:36 PM
Leave the crank behind.
Park on a hill . . . .
denniskliesen 07-12-2017 12:41 PM
All of my tools, jack and handles, crank handle, towels, go under the rear seat.
RawhideKid 07-12-2017 02:19 PM
Originally Posted by CHuDWah (Post 1498183)
Doesn't that make sitting kinda uncomfortable?;)
Not when it's the AAA card and the fellow using his jack and handle are changing the tire! :rolleyes:
Stew Masche 07-12-2017 03:14 PM
Crank usually sits in the passenger seat.
Big hammer 07-12-2017 03:21 PM
My dad wanted my hand crank! because he didn't want me hand cranking.
But dad want if I have a flat and need to put on the spare? Don't hand crank it, if it doesn't break your arm, I will ! Yes I did, many years later, it started right up!
