The Ford Barn
-   -   Harmon Collins dual point Distributor (https://www.fordbarn.com/forum/showthread.php?t=223875)
cobbie 07-01-2017 11:47 PM
I need some help, I purchased a bunch flathead parts, and found a Harmon Collins dual point Distributor with dual Mallory Condensers, The Distributor is in very good condition, points both look very good. Missing the name plate and of course the expensive rotor and cap. I have no use for this as I am running an 8BA. I have no Idea of the approx value ?? I plan on selling if there is much value to lower the cost of the rest of the parts, any help would be appreciated.
Cobbie
JWL 07-02-2017 05:44 AM
Re: Harmon Collins dual point Distributor
Not just a dual point but actually a dual coil distributor. I am not up to speed on current valuation but the "dual coil" is worth considerably more than a "dual point.
JM 35 Sedan 07-02-2017 07:51 AM
Just an FYI...the HC rotors are being reproduced, and the outer cap that's currently being offered by Bob Drake for use on the Ford crab distributor will also work on HC, but some firing order numbers would need to be corrected when used on HC.
I have recently seen these complete HC distributors selling in the range of $400.00 to $500.00.
deuce_roadster 07-02-2017 11:40 AM
These give 70degrees of dwell when set up properly.
cobbie 07-04-2017 01:37 PM
JWL
thanks for your reply but you say dual coil, I only see one place for the coil to plug in, I know that I don't have the cap but am I missing something.
weemark 07-04-2017 01:44 PM
those two round cylinder things which are upside down are coils. there a complete one on ebay just now for $299 buy it now.
BUBBAS IGNITION 07-04-2017 02:13 PM
Originally Posted by cobbie (Post 1494553)
JWL
One coil goes to center cap and the other coil goes to the outter cap .......
Mart 07-04-2017 02:23 PM
Mark, me old mate, they're condensors! Big brass ones!
Mart.
V8COOPMAN 07-04-2017 02:49 PM
Maybe this pic helps? DD
http://i18.photobucket.com/albums/b1...llins/HCdp.jpg
cobbie 07-04-2017 03:32 PM
Thanks,
That makes since now, I was not doubting JWL . I did know the 2 brass pieces were condensers. Thanks Bubba's and V8COOPMAN.
Cobbie
KiWinUS 07-04-2017 03:40 PM
Be sure you want to sell this !!! These are great distributors.
Cheers
Tony
cobbie 07-04-2017 04:42 PM
yes,
it won't fit an 8BA I would like to trade it for one that does. Any one know where I can buy a name tag for Harmon Collins.
Cobbie
Bob C 07-04-2017 04:58 PM
1 Attachment(s)
Here's one that didn't sell on epay. http://www.ebay.com/itm/VINTAGE-NOS-...p2047675.l2557
Bob
BUBBAS IGNITION 07-04-2017 06:22 PM
Bob
wow. i see why 1000
PeteVS 07-04-2017 09:22 PM
Mart.
So that's what they're talking about when they say someone has big brass ones? Condensors?
itslow 07-04-2017 10:14 PM
The Harmon Collins distributors for the later engines are less common than those for the early engines like what Cobbie has.
