Gas tank question - 46 Mercury What do any of you experts suggest to use as insulation between top of new tank and floorboard? Old tank has a couple of very original (and falling apart) strips of felt-like material. Hate to try to re-use these. Thanks in advance.
Re: Gas tank question - 46 Mercury Quote:
That,s what I used. |
Re: Gas tank question - 46 Mercury Why not use the tar like material that is used on more modern car/trucks?
Replacement part providers who have the kits, supply jute pads like the originals were. |
Re: Gas tank question - 46 Mercury Before I switched to a plastic tank, we used strips of inner tube rubber to line the straps. Metal tanks almost always develop pin hole leaks on the top from the road junk thrown up by the wheels when it gets wet. If you smell gas in or around the car, that is almost always the cause.
Re: Gas tank question - 46 Mercury There is a oil soaked cloth that is used on the 42 between the front and rear gravel gaurds and the body. That's what I used. Is a very heavy cloth.
Re: Gas tank question - 46 Mercury When you are comparing floor rust under carpet with jute padding, that's really not an accurate comparison. Carpet or rubber floor mats with just pad collect moisture due to the conditions that can occur in the cab plus Ford didn't do all that good a job at corrosion preventative measures for the steel there. Rubber floor mats are generally better but I remember watching old geezers hose out the floor area after a rains and muddy conditions warranted it.
The felt pads that were used on a lot of fuel tanks were narrow strips generally no more than 2-inches wide and around a foot long. The felt lasts forever and the tanks were tern plated from new so I don't recall ever seeing much corrosion of the top of a tank. The felt strips dry out a lot quicker if they get moisture up there. Foam of any kind does not last anywhere near as long. It will crumble to dust in those conditions after little more than 15 to 20-years or less depending on the quality of the foam. We still use felt padding in the engine baffles of airplanes and helicopters. It's the only thing that lasts any time at all under harsh conditions with heat and weather. McMaster Carr is a good source for felt strips of various widths and thicknesses. |
Even your suggested closed cell foam will entrap water under it. I have never seen the top of a gas tank (where the jute is used) have any indication of rust because of it's presence. |
Re: Gas tank question - 46 Mercury When removing the gas tank from my 48 I found no rust on the floor right over the tank and the jute strips were dry. The floor on the edges not protected by the tank and exposed have rust. I replaced the old strips with new ones.
Re: Gas tank question - 46 Mercury Thanks everybody for your input. Very helpful.
Re: Gas tank question - 46 Mercury I used strips of sheet rubber I cut up.
Re: Gas tank question - 46 Mercury How about strips of tar paper?
Re: Gas tank question - 46 Mercury Thanks again for the comments.
Re: Gas tank question - 46 Mercury Was able to find some very nice jute padding at my local auto upholstery store. Since I do not plan to drive the car in the rain, I feel OK using this. Thanks again for all the comments.
