The Ford Barn
-   -   Wiring with voltage regulator (https://www.fordbarn.com/forum/showthread.php?t=222481)
ktgarcia 06-11-2017 07:41 AM
I am finishing up wiring on my 1939 Pickup. The wiring harness I purchased shows has a YB (Yellow Black) wire connecting from the generator to one side of the single fuse block.
However, the truck was converted and uses a voltage regulator with a two brush generator. The generator has three terminals; armature, field, and ground. These terminals on the generator will have wires connecting to the voltage regulators armature and field terminals with the ground wire connecting to the mounting screw holding the regulator.
What I am wondering, does the YB wire from my 1939 wiring harness connect to the battery side of the voltage regulator as the cutout on the generator is now gone? I hope I am explaining this properly and appreciate any advice. Thanks.
flatheadmurre 06-11-2017 07:48 AM
Re: Wiring with voltage regulator
You got it right what used to go to the cutout now goes to the batteryconnection at the regulator.
JSeery 06-11-2017 08:06 AM
1 Attachment(s)
Yep. The wire marked to Battery in this diagram is to the connection on the Battery side of the Fuse block. The other connections shown on the generator (the ones with the arrows pointing to them) are test equipment hook ups and not part of the wiring.
cas3 06-11-2017 03:04 PM
1 Attachment(s)
heres how i did the same 2 brush job in a 34. attractive? not sure, but easy, and no holes drilled in the body.
ktgarcia 06-12-2017 11:27 AM
Thanks for the replys. I will try and finish up my wiring today.
