Correct the Zenith leaking fuel After first starting my fresh rebuild I noticed the carb leaking. Cleaned the ball valve(that replaced the needle valve) . Here is a short video shows the correct setting for the float level. Hope this helps some members not familiar with this procedure. Frank PKNY
https://www.youtube.com/watch?v=WwRZCws8EeQ |
Re: Correct the Zenith leaking fuel Good video Frank. Thanks for posting.
Jeff |
