The Ford Barn
-   -   Sioux Valve Grinding Coolant (https://www.fordbarn.com/forum/showthread.php?t=221131)
Afordman31 05-20-2017 04:32 PM
Been looking on the Internet about coolant for a Sioux valve grinder.
I see some people use automatic transmission fluid.
Another person said Marvel Mystery Oil.
Any thoughts on these.
I don't want to use anything with water in it as the machine is in a unheated spot. Thanks
Russ/40 05-20-2017 07:17 PM
Re: Sioux Valve Grinding Coolant
Goodson has the correct coolant, as well as a lot of the supplies.
BRENT in 10-uh-C 05-21-2017 12:55 AM
Originally Posted by Russ/40 (Post 1475168)
Goodsen has the correct coolant, as well as a lot of the supplies.
Yes, use the correct coolant for several reasons. Another source that I like better than Goodson is Cylinder Head Supply. (Better prices)
Jim Brierley 05-21-2017 10:13 AM
I've been using diesel fuel.
