head bolts Just putting my motor back in the roadster and wondered if you use anything on the bottom of the studs for sealant, or maybe loctite?
Re: head bolts I would use anti-seize so they can be removed at the next rebuild.
Re: head bolts You do not use loctite, and if you what to know anti-seize is plumbers pipe thread sealant. If you go to a hardware store ask for anti-seize they will know what you what.
Re: head bolts I guess you know how far to screw them in.
John |
