The Ford Barn
-   -   Distributor Hold Down (https://www.fordbarn.com/forum/showthread.php?t=218973)
Towd56 04-17-2017 12:39 PM
1 Attachment(s)
I have what I believe to be a Mallory electronic distributor. Im looking for the hold down device that clamps around dist. Shaft and then sits in the head with a pin. Anyone know where I can get the right one?.
I'm afraid if I just use the set screw - the dist. Will walk on me- throwing it out. As you can see my head is aluminum so I don't want to put a lot of torque on that set screw.
Thanks
redmodelt 04-17-2017 03:54 PM
Re: Distributor Hold Down
Yes, Tom makes them for WICO mags which have the same shaft (like all Model A and B's) size. Sent you a PM with Tom's phone number. They are 50$ Postage payed US.
BILL WILLIAMSON 04-17-2017 04:50 PM
With Minervas' Mallory, I just ground a SHARP point on the SET SCREW. NEVER came loose!
Chief always said, "THE EASIEST WAY IS THE BEST WAY, IF IT DOES THE JOB PROPERLY"!!!----He also said, "PATCH UP JOBS ARE ONLY MEANT TO GET YOU HOME, IN TIME FOR SUPPER"!!---He also said, "PATCH UP JOBS WILL COME BACK TO HAUNT YOU, 90% OF THE TIME"!!!
Chiefs' Son
redmodelt 04-17-2017 08:15 PM
Would be better to have the clamp with pin and machine a groove around the shaft like the A distributor. Call Tom, he has done several.
Towd56 04-17-2017 10:32 PM
I will give him a call. Thanks
