Wire Clips locations Does anyone have a diagram for a 1930 Town Sedan (Murray) showing where the wire clips are located along the frame and where clips should be located along the back (on the wood) if you have two tail lamps?
Re: Wire Clips locations Let's see that the standards have to say;
"The rear lamp wiring was routed under the rear motor mount to the bottom inside of the left rail and fastened with a clip. It was then routed through the center cross member with the transmission mounted stoplight switch or under the cross member with the cross member mounted switch, and along the bottom inside of the lower left rail, fastened with three clips. The harness was routed to the frame upper rear corner bracket where it was fastened with a clip. Passenger vehicles with the drum type rear lamp had two clips holding the wires to the lamp support. Later models had the lamp extension wires attached to the rear fender bracket or fender skirt with a special clip. Beginning early 1929 a clip (A- 14592) was used to support the wiring to the bottom of some wood framed bodies just rearward of the rear cross member. The clip was attached to the left floor sill with a #10 black enameled round head wood screw. Applicable bodies included Fordors, Station Wagons, Panel Deliveries, and 78-B pickups. All clips were black enameled." In 1930 the factory would not have wired an additional tail light so the method of fastening the the wire would have been up to the installer. Sorry, but the uploading part of this site is down at this time to up load the different types of clips (page 2-16) |
Re: Wire Clips locations Page 586 of the Service Bulletins tells how to wire the extra tail light.
Bob |
Re: Wire Clips locations I place them wherever they provide the MOST protection from damage.
Bill Careful |
Re: Wire Clips locations Thanks everyone for your answers - now back to the garage to see what I can do
I didn't look in the correct part of the Judging Standards where the answer was |
Re: Wire Clips locations If your frame is freshly finished be careful sliding them on. They will scratch it right down to the bare metal. I spread them with a snap ring pliers as i install them..
Re: Wire Clips locations Thanks Mitch//pa for this information - I was only missing a couple and have to install correct ones for the tail lamp cross-over wire. I had 2 - need a couple more for the cross-over wire (Next parts order) Frame is not freshly painted (original car) so not an issue
