The Ford Barn
-   -   b trans value (https://www.fordbarn.com/forum/showthread.php?t=217585)
aussiesteve 03-27-2017 07:38 PM
b trans value
Today I scored a complete b trans inc shifter,trans mount,e brake and clutch arm
I grabbed it as I need the 32 clutch arm.
The trans has a broken case
Is it worth anything?
Thanks
Lawrie 03-27-2017 07:39 PM
Re: b trans value
Maybe put it on the A forum, the guts will fit you 32 case I think
Lawrie
DavidG 03-27-2017 08:02 PM
Re: b trans value
The innards are same for all '33-'34 fours and eights except big trucks. There's demand for the clutch arm, but you're keeping that, less demand for the hand brake, rear mount, and shift lever housing, and very little for used gears. A broken case, zero except for scrap.
Lawrie 03-27-2017 08:41 PM
Re: b trans value
I have a case if you need it.
Lawrie
aussiesteve 03-27-2017 10:17 PM
Re: b trans value
Lawrie
Thanks for the offerLawrie but you are a little from me
